Hi, I've selected various products as the toggle - featured. How do I get these products to appear on the homepage??? Under the slider? Thanks in advance. Philip
Hello, Follow the instruction given below. 1. Firstly install and activate the theme Woocommerce plugin. 2. Just create product categories (product > categories) and assign products to those categories. They will automatically display at the front page. See the link given below for reference. http://screencast.com/t/yj44pSLl9sR This will solve your issue.
Hi, Sorry You misread my question, I'm looking to get only the featured products on the home page. I know I can display products by category under the slider - But is there any way to display featured products only? I've tried creating a category - Featured products and adding the products to this category and then displaying only this category from the theme settings - but that doesn't seem to work either. Surely there is a line of code I can insert into the index.php to display the featured products - The ones which I have selected by toggle as featured? Thanks Philip.
Try this: Go to Products > Look for the specific product you want to feature > third column from the right you'll see a "star". Click on the star in the product's row. That should make it a featured product.
