Problem with effects in category menu
Discussion in 'BlogsTrend WordPress Theme' started by ehodecker, Feb 4, 2014.
  1. ehodecker
    ehodecker New Member
    United States
    Good afternoon,
    I am currently using the Blogstrend Theme and love it. I seemed to have developed a little glitch however. On my category menu (not the one running at the top, but under the header) ... I am having an issue with the "mouse-over" effect that highlights the current page you are on. Specifically, the text on the "home" button seems to be covered by something. This problem only seems to happen for the home page category.
    If it's a minor glitch, I am sure I can fix it with the right direction. Any help would be appreciated.
    http://yourincomeformula.com
    The website link you have sent is not working, it seems that there is some text missing in the web address. So check the link again and resend to us. So that we can check your issue.
    Gourav Shrivastava
  3. ehodecker
    United States
  4. ehodecker
    United States
    The link is working fine for me, but once again: http://www.yourincomeformula.com
  5. Piyush
  6. ehodecker
    United States
    I just installed the latest version, but the problem sill seems to be there. Please note it's not a huge issue, but it would be interesting to see why the problem seemed to magically appear.
  7. ehodecker
    United States
    If anyone has a fix for this problem, that would be great. I deleted the old theme and installed the newest version, but the problem still persists. Thank you in advance. Eric
  8. Gourav
    Paste this code in Custom CSS
    #menu .ddsmoothmenu li a:hover, #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li.current-cat a {
    background-color: #7da512!important;
    Gourav Shrivastava
  9. ehodecker
    United States
    Thank you very much. As you said, this solved the issue. It was a small problem that nobody may ever have noticed, but it was driving me crazy. I love the theme, and thank you for resolving the problem.
    Eric
    Piyush likes this.
