Pages Navigation menu not working on mobile devices
Discussion in 'Themia WordPress Theme' started by joannamca, Nov 16, 2012.
  1. joannamca
    joannamca New Member
    Please advise a fix for the pages navigation menu. It is not working on any mobile devices. Will not drop down to the pages within the site. They display for a brief second and then disappear.
  2. Harmeet
    Harmeet Support Staff
    Can you please share the link of your website. So that we can check the issue.
  3. joannamca
    Yes, our website is www.trunorthglobal.com It is really important that we able to access via mobile devices (iPhone, iPad, Android, BB).
  4. joannamca
    I sent this to you Friday and have not heard back. www.TruNorthGlobal.com Support, please?
  5. joannamca
    FYI I have found and fixed the problem with the theme.
    The problem is that the 'mobile-menu.js' script gets included twice at the end of footer.php
    Once explicitly, then a second time by the wp_footer() function.
    It works fine if its only included once.
    -David Granz
  6. skintouchtherapy
    skintouchtherapy New Member
    I have this issue too. Can you post a link, showing where I need to make the changes. My website is www.skintouchtherapy.com
  7. Gourav
    We have visited your website the problem is occurring due to any one of the plugin you are using, Deactivate all plugins one by one and checkout which plugin creating this problem.
  8. jonvan
    jonvan New Member
    don't think it's a plug in issue as I have the same issue. is there a certain line or code to remove? what is it?
  9. Nitesh
    We are looking to your issue and will reply you as soon as possible.
  10. Nitesh
    This issue is resolved. Please download theme from members area.
    And upload it, It will resolve your issue.
