Hello, To remove login, Register menu from the top. Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: #menu .dd1smoothmenu.admin-menu li a { display: none; } To remove bar completely. Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .top_cartinfo { display: none; } Thanks & Regards Nitesh Raghuwanshi
I tried the code above but I can't get the top right login and reg info to remove> Please advise, thanks! http://awesomescreenshot.com/0472f2p32e
Hello, Paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: #menu1 .dd1smoothmenu.admin-menu li a { display: none; } #menu1 .smoothmenu.admin-menu li a{ display: none; } This will solve your issue.
When I use this custom code, it removes some of the info at the top but it leaves the two white bullets. And for some reason they are on two rows versus same row: http://awesomescreenshot.com/08f2hbpa30
