CSS custom code to remove and adjust gaps
Discussion in 'GoldenEagle WordPress Theme' started by gavinbrooks, Mar 20, 2014.
  1. gavinbrooks
    gavinbrooks New Member
    Loudwater, High Water, United Kingdom
    Can I have help please with custom CSS codes to the following as shown in two pictures please:
    Many thanks.
    Gavin
    .main_container {
    margin-top: 0px;
    #slides .prev {
    #slides .next {
    .pagination {
    .feature-content {
    padding: 5px 0;
    .feature-strip {
    padding: 12px 0 9px 0;
    margin-top: 5px;
    margin-bottom: 5px;
    .footer {
    You can adjust the "margin" and "padding" as per your requirement.
  3. gavinbrooks
    Thank you very much it works :)
    Just one little question, when I remove the long bar and dots using this:
    .pagination {
    Whats the CSS code to remove the empty container or space it was sitting in please?
  4. gavinbrooks
    And can I use custom CSS to add a red border around the edges of the main content boxes and the boxes below it?
  5. Piyush
    .content {
    margin-top: 20px;
    .main_container {
    padding: 5px 0;
  6. Piyush
    .main_container {
    border: 2px solid red;
    .feature-content {
