Changing color of theme
Discussion in 'Infoway WordPress Theme' started by qubit2010, Mar 29, 2014.
  1. qubit2010
    qubit2010 Guest
    thank you piyush for the reply... this does not serves the purpose actually because i want to change the color of carousel in this screen shot...please look into this...
      File size:
      337.8 KB
      2
    .showcase-thumbnail-content h3 {
    color: red;
  3. qubit2010
    qubit2010 Guest
    If i want to change the background color as orange....not text color....
  4. Piyush
  5. qubit2010
    qubit2010 Guest
    sure....Please find attached....
      File size:
      304.3 KB
      5
  6. Piyush
    It is an image not a color in the background, If you want to change its color then,
    Go to images directory present in your theme directory and replace your image with present slidertextbgnew.png image or edit it.
    The name of image is "slidertextbgnew.png".
  7. qubit2010
    qubit2010 Guest
    I did that the same you told me but it is not reflecting ....you want me to change slidertextbgnew.png or slidertextbg only.....
  8. Piyush
  9. qubit2010
    qubit2010 Guest
    hi,
    I have changed from black color to orange but it is not showing orange..it is still showing black.... I don't think its changed....
    Can u please check this again...
  10. qubit2010
    qubit2010 Guest
    sorry ... it has been changed successfully... thank you for your support.... as you can see on my website I have used contact us tab in Infobar on top right... if I want to use image in box where contact us is place.... can I able to add image...???
  11. Piyush
    Go to the header.php file present in your theme directory and paste the code given below in that file as instructed in the image given below.
    <p><img src="Enter Your Image Url Address here"></p>
  12. qubit2010
    qubit2010 Guest
    Hi all,
    1. I want to remove section below the slider in Www.qubitinformationsystems.com please check and let me know how can I remove...
    2. How to change the font size in footer.
    3. How to remove cone on the top
  13. Gourav
    Paste this code in Custom CSS
     a.readmore {
    display: none!important;
    .footer ul li a {
    font-size: 15px;
    line-height: 28px;
    .footer .footer_widget h4 {
    font-size: 23px;
    Could you please explain your problem with the help of screenshot, where you want to remove(remove cone on the top), so that we can give you the exact solution.
    Gourav Shrivastava
  14. qubit2010
    qubit2010 Guest
    hi i have website www.qubitinformationsystems.com i have some points which i want to discuss with you.:-
    1.I want to reduce the white gap between carousal and tag line.
    2. I want to format word "How we work" to "How We Work" in footer how can i do.
    Jigyasu.
  15. qubit2010
    qubit2010 Guest
    Hi on my website...www.qubitinformationsystems.com I have done many changes I want to remove the white space which is available in between carousal and tag line...how can I remove this white space...?
  16. Gourav
    .contentbox {
    .testimonial{
    padding-top:0;
    text-transform: capitalize;
    Gourav Shrivastava
  17. qubit2010
    qubit2010 Guest
    This option is not working fine... can u please tell me how to change color of image on contact us tab in top infobar...
  18. Piyush
  19. qubit2010
    qubit2010 Guest
    Hi Piyush,
    Please check the image shown below and i want to change the color of contact us tab to color of our theme which is Burnt orange.
    Jigasu.
      File size:
      1,004 bytes
      3
  20. Piyush
    .topinfobar .siteinfourl p {
    background-color: red;
