Changing color of theme
Discussion in 'Infoway WordPress Theme' started by qubit2010, Mar 29, 2014.
  1. qubit2010
    qubit2010 Guest
    Hi All,
    I have bought this theme few days ago, I want to change the color of theme which is on this site.. http://www.thereview.info and my site on which m working is http://www.qubitinformationsystems.com I have searched on theme I was not able to find this color in theme options due to this color we bought this theme if we are not able to use this color them this theme is useless for us.
    Please feel free to contact me.
    Jigyasu.
    9891908408.
    Go to
    Appearance > Theme Option > Styling Option > Theme Stylesheet
    and change theme color scheme from there.
    Gourav Shrivastava
  3. Piyush
    Hello Jigyasu,
    In this theme the default color is orange.
    Go to the Appearance > Theme options > Styling Options panel in your dashboard and select default color scheme from Theme Stylesheet section.
  4. qubit2010
    qubit2010 Guest
    Thank you piyush for your reply what is have undestood is orange color is default colour so If I would use default option in styling it will should me that color .... m I right...?
  5. qubit2010
    qubit2010 Guest
    Thank you all... same has been done.. I have 1 more concern how to change the font size of header menu.
  6. Piyush
    #menu .ddsmoothmenu li a {
    font-size: 18px;
    You can change the value of "font-size" as per requirement.
  7. qubit2010
    qubit2010 Guest
    This is changing the color of main headings on but i need to change the size of drop down menus as well.
  8. Piyush
  9. qubit2010
    qubit2010 Guest
    Thank you itz done now...if i want to remove close option on infobar and click here button how can i remove that....
  10. Gourav
    Paste this code in Custom CSS
    .closeicon {
    Gourav Shrivastava
  11. qubit2010
    qubit2010 Guest
    thank you Gourav for your instant support...1 thing more how can I add secondary Menu in footer in this theme..
  12. Gourav
    Go to
    Appearance > Menus
    Create a custom menu and only add the pages that you want to show in the navigation bar.
    Now,
    Go to
    Appearance > Widget
    Drag Custom Menu widgets and select your menu from its option and drop it in the first widget area.
    Gourav Shrivastava
  13. qubit2010
    qubit2010 Guest
    Thank you for reply but i know this process which you are talking about and i have already created that on my site if u see on www.qubitinformationsystems.com. But my question really is that if i want to add menu vertically in footer like you see in image below. How to add this...[​IMG]
      File size:
      4 KB
      3
  14. Piyush
  15. qubit2010
    qubit2010 Guest
    thank you piyush for your reply... how can i remove Lead capture form from home page...
  16. Piyush
    Go to the Appearance > Widgets panel in your dashboard and
    drag & drop your Widget in the Home Page Right Feature Widget Area.
    This will remove the default Lead capture form and display your widget on the home page.
  17. qubit2010
    qubit2010 Guest
    thank you piyush same has been done for now...... how to remove featured text on home page....Please find the screen shot attached...and how to move three featured tabs just below carousel ....
      File size:
      31.7 KB
      1
  18. qubit2010
    qubit2010 Guest
    adding in last question how to change the color of carousel headings...
  19. Piyush
    .slider_wrapper .infotag {
    This will remove the featured text on home page.
    To move three featured tabs just below carousel,
    Download the front-page.php file attached with this post and replace it with your existing front-page.php present in your theme directory.
    This will move three featured tabs just below carousel.
  20. Piyush
    #carousel-full .carousel-posts li h6 a {
    color: red;
