Text not visible in Top Header Right Bar
Discussion in 'Slice WordPress Theme' started by niallg, Sep 22, 2014.
  1. niallg
    niallg Member
    My text is not visible in Top Header Right Bar how do I change colour of text in this bar and also in other areas ?
  2. Pramod
    Pramod Guest
    Please provide URL of website.
    Pramod
  3. niallg
    niallg Member
  4. Pramod
    Pramod Guest
    You have to follow two steps-
    Step-1:
    please follow below image.
    Step-2:
    fieldset.add p {
    color: green !important;
    You can change color according to your need.
    Pramod
  5. niallg
    niallg Member
    Thank you for that , now how do I change the size of the font ? and centre the text so that it is in the middle ? that is the blue text in the top header right bar ?
  6. niallg
    niallg Member
    I would like to place some images of logos on the bottom of the home page under the First Feature column image , second and third feature column images
    I am trying to replicate the bottom of the homepage (old Site) www.beralon.com , could these appear on the bottom of each page ? Thank you again.
  7. Pramod
    Pramod Guest
    Use these code in custom CSS
    set according to you need.
    fieldset.add p {
    color: blue !important;
    font-size: 45px !important;
    line-height: 30px !important;
    text-align: center;
    fieldset.add {
    margin-right: 43px;
    You can add images in footer section widget area which appear in every pages..
    Pramod
  8. niallg
    niallg Member
    Hi Pramod,
    how do I centre the blue text Eg . " one of the most experienced and qualified chemical cleaning companies in Australia.
    The best solution for your chemical cleaning needs."
    also I need to align this with the logo so that it looks good.
    Thank You
    Niall
  9. niallg
    niallg Member
    Hi Pramod,
    The text needs to have the sentences one on top of the other
    Regards
    Niall
  10. niallg
    niallg Member
    Re - thread My text is not visible in Top Header Right Bar how do I change colour of text in this bar and also in other areas ? I have added another question
    how do I centre the blue text in the Top Header Right Bar Eg . " one of the most experienced and qualified chemical cleaning companies in Australia.
  11. niallg
    niallg Member
    I have uploaded a jpg that shows what I mean re Top Header Right Bar
    Regards
    Niall
  12. Pramod
    Pramod Guest
    There is not any text in your header section which is invisible. Did you remove text?
    Pramod
  13. niallg
    niallg Member
  14. Yogesh
    Yogesh Guest
    Hello Niall,
    1. Open header.php file and find this code( <div class="grid_16 alpha"> ) then make it <div class="grid_10 alpha">.
    Again find <div class="grid_8 omega"> then make it <div class="grid_14 omega">.
    2. Paste the code given below in Custom CSS section
    fieldset.add p {
    text-align: center;
    margin-top: 85px;
    It will resolve your issue.
    Yogesh Bhade
