Slider not working
Discussion in 'Smartbooking-Appointment Booking WordPress Theme.' started by cybrain, May 15, 2016.
  1. cybrain
    cybrain New Member
    Netherlands
    Just finished installing the smart booking theme. I also managed to create images for the slider at the correct sizes as given in the settings. Somehow the theme has a difficulty in uploading the image.
    However the images appear in the wp upload directory, but the theme is still trying to upload it.
    But that is not the problem, I copied the correct html to the image direct into the theme slider settings.
    Even checked in the source and the image links are present.
    So far so good, but the slider does not work, it is on 5000ms. But it is only showing the first picture and a small piece of the second under the first en it does not slide at all. all pictures (4) are the same size (1600px x 640px).
    I am using the latest wp fresh install and no plugins at this moment. problem is the same in IE10 and Chrome.
    Any ideas?
    grtz
    Cybrain
    Hi, Cybrain..
  3. cybrain
    cybrain New Member
    Netherlands
    Hi Priya,
    here is the url : http://wp.mandisakura.nl/
    It is a test url where I am building my new site.
    If you need more info let me know please. ;)
    grtz
    Cybrain
    Your Website URL:
    WordPress Username:
    Password :
  5. priya
    Your issue has been resolved..
    Kindly check your site..
