Responsive issue, menu dropdown
Discussion in 'Themia WordPress Theme' started by madsweiss, Apr 11, 2013.
  1. madsweiss
    madsweiss New Member
    Hi Guys
    I have bought the responsive theme and are using the appearance>menus option to catagorize my pages on the site. The problem seem to occur when i test the responsive part in the web browser, or on my mobile device. When comprimizing the screen size the different menu tabs dissapear and a new dropdown menu occurs. But, nothing happens when i press the dropdown icon??
    Please help!? :)
    Best Regards
    Mads Hansen, Denmark
  2. lcarlton11
    lcarlton11 New Member
    I was having that same problem and found out it worked when I deactivated "Jetpack for wordpress.com". Now I have the responsive menu with the Colorway theme Pro in a narrow browser, but have to figure out what to do about the Jetpack plugin I was using.
    www.oldemillfurniture.com
  3. Gourav
    This issue maybe because of plugin (if installed). So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin.
