Remove slider heading...
Discussion in 'BlackBird WordPress Theme' started by lauramts123, Jan 24, 2016.
  1. lauramts123
    lauramts123 New Member
    1084 Lancaster Avenue Bryn Mawr, PA 19010
    .flex-caption {
  3. safdaarh
    safdaarh New Member
    hello,
    how do you make the Heading (box) on the slider Transparent ?
  4. Naveen
    To make your slider caption transparent, you need to paste below CSS code in Custom CSS field located in Dashboard->Appearance->Theme Options->Styling Options
    .flex-caption {
        background: none;
    This will resolve your issue,
    Warm Regards!
    Naveen Kolhe
  5. safdaarh
    safdaarh New Member
    Hi Naveen, Thanks for the tip..I was also interested in making the slider caption with transparency as appeared in the following site I saw : http://www.limousine-klagenfurt.com/ru/
    Please for the codes for this, many thanks
  6. Naveen
    Just use the same code there as well. It will work.
  7. safdaarh
    safdaarh New Member
    This set of codes
    .flex-caption {
    background: none;
    removes the box completely but like in the site http://www.limousine-klagenfurt.com/ru/ the box is still visible yet transparent. I need a code for this please.
  8. safdaarh
    safdaarh New Member
    This set of codes
    .flex-caption {
    background: none;
  9. Naveen
    It seems you want the transparency in that caption area, right?
    Just use below code:
    .flex-caption {
        opacity: .65;
        filter: alpha(opacity=65);
    Warm Regards!
    Naveen Kolhe
  10. safdaarh
    safdaarh New Member
    Thank you very Much Mr Naveen...this does the trick :)
  11. Naveen
    You are most welcome :)
