Ink theme branding on front page of traffica pro
Discussion in 'Traffica WordPress Theme' started by cyberman, Jun 11, 2017.
  1. cyberman
    cyberman New Member
    Hi, I would like to remove the ink themes logo and web redirect on the front page bottom of the theme
    example: our blog, about us, what our clients say
    I tried widgets but didn't seem to work....
  2. akbar92
    It would be better for us to understand your query with the help of some edited screenshots.
    Please share some screenshots of the concerned areas of your site.
    Akbar
  3. nrosson
    nrosson New Member
    Hello, I too would like to remove the inkthem brand...along with the inktheme image..how can do that...see items in screenshot below. How can I do that?
  4. Naveen
    You can simply configure the Home Page Sidebar Widget area with your Facebook code, Just visit your Dashboard->Appearance->Widgets and do the needful,
    Regarding the footer text, you can configure the same from Dashboard->InkThemes->Theme Options->Footer Settings
    Just put your text, it will replace our default one.
    Regards!
    Naveen Kolhe
  5. clawson
    clawson New Member
    Can I remove everything above? Services to Inkthemes Theme?
  6. akbar92
    Simply put a blank text widget in the Home Page Sidebar Widget area to remove InkThemes service logo, just go to your website dashboard (Dashboard->Appearance->Widgets), just follow the linked screenshot: https://screenpresso.com/=5ILce
    And to remove footer text, just put a single space in a footer text area, have a look at the linked screenshot: https://screenpresso.com/=OSk1g
    Hope you find above information helpful...
    Thanks & Regards,
    Akbar
