Home page is not showing the latest posts
Discussion in 'Compass WordPress Theme' started by tutit, May 7, 2017.
  1. tutit
    tutit New Member
    There are two posts and there are now showing on the home page
    Please your advice and help
    Tnx
    Sarit
  2. Naveen
    Hello Sarit,
    It seems you haven't configured the Featured Image for them, please check and use images for your posts.
    This will help you to figure it out and resolve the issue(s).
    Warm Regards!
    Naveen Kolhe
  3. tutit
    tutit New Member
    Hi Naveen
    i've configure the image in both posts but it seems something is missing in the code
    attaching a link so you can see
    http://www.5taichi.com/
    Regards
    Sarit
  4. Naveen
    Hello Sarit,
    We are unable to open your site, could you please share your WordPress admin credentials at [email protected]
    We will check and do the needful.
    Warm Regards!
    Naveen Kolhe
  5. richz
    richz New Member
    I have the same problem too.
      File size:
      150.4 KB
      3
  6. akbar92
    Hello Richz,
    We need your website C-Panel access to figure out the issue.
    C-Panel website URL: -
    C-Panel Username: -
    C-Panel Password: -
    Thanks & Regards,
    Akbar
  7. richz
    richz New Member
    I fix the problem,
    When I change the Compass Pro Options > 'Styling Options' > Theme Language from default to rtl .....the latest posts are display,
    May be this cause by some initial values are missing or some others reason ?
    My website default language setting is zh-TW.
  8. akbar92
    That sounds great :)
