Hello, Greetings from InkThemes! Could you please explain your issue with some edited screenshot and your site URL as well so that we can better assist you? If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Thanks & Regards! Priyanka InkThemes.com
FOr example I have places a widget Video category. But now I want to put the video_cat on the top menu instead of widget how do i do that ? ALso, can we have a dropdown list for the menu items? I want to have a menu called "video category" which is dropdown list. Is it possible and how ?
Hello, Yes, that is possible and for that you just need to follow the video given below. Link of the video: http://screenpresso.com/=SsWqe Hope you will find it helpful. Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thanks that works but i have another concern : I want to add bootstrap code into the theme. For example, I want to change the look of the dropdown list of "video category" and i have this code : <div class="dropdown"> <button class="btn btn-default dropdown-toggle" type="button" id="dropdownMenu1" data-toggle="dropdown" aria-haspopup="true" aria-expanded="true"> Dropdown <span class="caret"></span> </button> <ul class="dropdown-menu" aria-labelledby="dropdownMenu1"> <li><a href="#">Action</a></li> <li><a href="#">Another action</a></li> <li><a href="#">Something else here</a></li> <li role="separator" class="divider"></li> <li><a href="#">Separated link</a></li> </ul> </div> where should I place this code (which php file) ? and which line ? do i need to remove existing code for dropdown list ?
Hello, We are confused with your requirement that in which field you want to add the above code.. As far your above statement i.e. want to change the look of the drop down list, so let me tell you that you can easily do it by applying CSS code. So it would be better to explain your requirement with some edited screenshot of the concerned area and your site URL as well. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
pls find attached. I want to create something like this. And on mouse hover I need the text to be highlighted.
Hello, You can easily change color of the text while hovering, you just need to paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: #menu .ddsmoothmenu li a:hover { color: red !important; background: lightpink !important; } Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thank you .The hovering part works but as you can see, the shape of the box is rounded and also there is no lines to separate the categories. THe default dropdown is square shape and has lines to separate the list. How do I change the shape of the dropdown box ?
Please find attached pics and see the difference. I want to make changes (dropdown shape and style) to the circled area in the dropdown.png pic . As you can see in the "2015-12-08(1).png pic, the corners of the dropdown box are rounded and also there is no lines to separate the categories. The default dropdown style in the theme is square shape and has lines to separate the list. How do I change the shape of the default dropdown box to be like 2015-12-08(1).png?
Hello, It would be possible to give (not exact but almost same) look and feel of the menu list as you want, you can try below code in Custom CSS field of your dashboard. Code: #menu .ddsmoothmenu li ul li a:hover { background: lightgray !important; } #menu .ddsmoothmenu li ul { margin-top: 20px !important; margin-left: 6px !important; background: none; } Thanks & Regards! Priyanka InkThemes.com
