Changing Font Colors
Discussion in 'BlackWell-WordPress Business Theme.' started by lanabstephens, Oct 1, 2015.
  1. lanabstephens
    lanabstephens Guest
    I would like to change the font color of the text from dark gray (#6a6a6a) to something that stands out more on a dark background, such as white #ffffff.
    site link: pavolocotennis.com
    The sections are:
    Home Page Three Column Feature Heading & Description
    First Feature Heading
    Second Feature Heading
    Third Feature Heading
    Home Page Team Feature Heading & Description
    All four team areas.
    Basically any dark areas need to have lighter text so it will pop more. What do I need to include in the custom css box?
    Thank you!
    Please paste the CSS codes given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    1.) For main feature heading and description, code is given below.
    .feature_content .page_info h1 {
        color: red;
    .feature_content .page_info p {
        color: blue;
    2.) For Three Column Feature Heading & Description, code is given below.
    .feature_content .feature_content_inner h2 {
        color: red !important;
    .feature_content .feature_content_inner p {
        color: blue !important;
    3.) For Home Page Team Feature main Heading & Description, code is..
    .team-content .page_info h1 {
    .team-content .page_info p {
        color: white !important;
    3.) For inner Home Page Team Feature Heading & Description, code is given below.
    .team-content .team-item h4 {
    .team-content .team-item p {
    4.) To change link color, code is
    a {
    5.) To change span color of team blog, code is
    .team-content .team-item span {
    NOTE: Change color of the different column as per your requirement.
  3. lanabstephens
    lanabstephens Guest
    Thank you for pointing me in the right direction, and especially thank you for the timely reply.
    Cheers!
  4. lanabstephens
    lanabstephens Guest
    Just for the sake of accuracy, if anyone else uses this solution make sure to include the end bracket from the first section above:
    color: red;
    color: blue;
    The first closing } was missing in Priya's reply.
    Thank you!
  5. priya
    Yes that was my mistake, I am sorry for that :(
    Thanks for understanding the thing and for the correction as well..
