BlogSpring : managing widgets
Discussion in 'BlogSpring WordPress Theme.' started by jeanlouis, Nov 11, 2014.
  1. jeanlouis
    jeanlouis New Member
    When you are on a post page, 3 widgets are displayed by default in the right side bar : "Search", "Categories" and "Recent Posts".
    I would like to change the title of "Categories", remove "Recent Posts" and replace it by one or several other widgets.
    I have searched in the user manual and in the forum, and I didn't find any information about this topic.
    Can you tell me how to do ?
    Thanks in advance,
    Jean-Louis
  2. jeanlouis
    I don't understand why, but this problem is resolved...
    I updated the theme and tried to put <p></p> (see in the forum) in the
    concerned widgets areas, first all the widgets disappeared, I worried a lot,
    and then I tried to create a widget and it was OK.
    So, until the next time, I don't need your help anymore.
    Best regards,
    Jean-Louis
  3. Pramod
    Pramod Guest
    You can change title or another widgets according to your need.
    Please follow below image.
    Pramod
