Blog Author Name removal
Discussion in 'Foogo Pro WordPress Theme' started by proele, Aug 4, 2017.
  1. proele
    proele Member
    I need to remove the author name from all blog posts - I need it so that they never appear, how can I do this?
  2. akbar92
    To remove the author name from blog posts, just paste the code given below in Custom CSS section.
    .post .author-avatar {
    Hope this helps...!
    Akbar
  3. sphouston
    sphouston New Member
    This didnt work on my end
  4. akbar92
    Could you please share some edited screenshots of the concerned areas of your site along with site URL.
    Akbar
