Always Says: "Not Available" for times
Discussion in 'InkAppointment WordPress Plugin' started by netainment, Feb 22, 2017.
  1. netainment
    netainment New Member
    I was just testing out your plugin and I cannot get it to allow me to set up an appointment. Dates work fine - times show "not available" as soon as date is selected. I am using Layers (https://www.layerswp.com/) for my theme - do you know of any incompatibility?
    thanks
    don
  2. nitin
    nitin Guest
    It seems you might have missed something while installing/configuring the plugin.
    To determine and fix the issue, we need access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password :
    We will check the things from our end and will let you know what's missing.
    Nitin
  3. sixxroth
    sixxroth New Member
    Hi. I have the same issue. What is the solution?
    I am also not able to put it in a page in Wordpress. Only as a widget.
    I use Eclipse Pro 3 theme.
    Thanks.
  4. nitin
    nitin Guest
    If you are having the same issue then you are requested to kindly forward us your dashboard details at [email protected] along with the thread link containing the details requested below:-
    Your Website URL:
    WordPress Username:
    Password :
    We will check for the issue at our end.
    Next, to include the form on any other page, you can use the shortcode provided below on any of the pages that you want.
    [ink-appointments-form]
    Hope this helps...!
    Nitin
  5. sixxroth
    sixxroth New Member
    I already sent all info to you. But haven't received any reply.
  6. nitin
    nitin Guest
    Can you please let us know the e-mail address with which you sent the details so that we could locate it at our end and can assist you ASAP.
    Looking forward to hear from you.
    Nitin
  7. netainment
    Had some time today to look at this and I think it's a server config issue. I think the ajax call for getting the available times is not working. Can you tell me what page (URL) the script is accessing during its ajax call for available times so I can check what the response actually is?
  8. emmamorgan
    emmamorgan Member
    You do realise that you have to select a service before you can select a time?
  9. netainment
    Hi Emma,
    Yes, thanks, I can select a service and a date, but then time always shows "not available". I think my problem is the response from the server on an ajax call for the open times.
  10. brodephat
    brodephat New Member
    Hmmm same issue here. "Not Available" comes up no matter what I do. I'll send the info as stated above.
  11. Naveen
    Did you configure the time slots properly from the plugin's backend options?
    If yes then, Would you please check your site by disabling other plugins once.
    It seems some other plugins are conflicting the functionality of ours.
    Warm Regards!
    Naveen Kolhe
  12. noniej
    noniej New Member
    I've got the same issue. It's all set up properly but no times available. When I click on manual appointments in the Dashboard the form appears perfectly. Please respond.
  13. Naveen
    You might be missing to configure the time slots properly, please refer the video tutorial that I have posted in this thread: https://inkthemes.com/community/threads/cant-get-select-time-to-work.20931/
    You will be able to figure it out.
    Else, you can share your WordPress admin credentials at [email protected]
    We will check and do the needful.
    Warm Regards!
    Naveen Kolhe
