404 error re Inkthemes leadscapturepro
Discussion in 'Infoway WordPress Theme' started by bizgirl, Apr 8, 2017.
  1. bizgirl
    bizgirl Member
    Hi guys,
    I am troubleshooting an error for the Thrive Content Builder Plugin on my site.
    After following their instructions at https://thrivethemes.com/tkb_item/e...hen-trying-to-save-internal-server-error-500/
    the following errors appear when I hit F12 on my keyboard as per the image below..
    Could you please check this out as I am unable to use the plugin.
    This is for the site www.maroochydoreroos.com and I have recently sent through the credentials.
    If there is something I can do please let me know.
    Cheers,
    Maggie
  2. Naveen
    For your information, it may happen that some of your plugins are conflicting in your site,
    You are requested to deactivate all of your plugins once and check your site again,
    Then activate one by one your plugins checking result on each activation,
    Hope this will let you figure out the problematic plugin.
    Warm Regards!
    Naveen Kolhe
