Two comment questions
Discussion in 'SwiftRay WordPress Theme' started by jlewtoo, Feb 18, 2013.
  1. jlewtoo
    jlewtoo New Member
    Irvine, CA
    I have two questions about the comment form. I am trying to delete the text (see attachment) underneath the comment form in the news section of the website and can't locate where to do this.
    I am also trying to create a page that will act as an online commenting forum, however when I try to change the page type to blog to allow for commenting, the page disappears and redirects to the posts section. Can you please advise how to accomplish this? Do I need to turn on comments to do this? I tried adding code as directed but still not showing a comment option. Can you turn on/turn off comments per page?
    Link is http://dads4specialkids.lammconsultingservices.com.
  2. leonkill2000
    leonkill2000 Member
    If you go to All Pages and click on 'Quick Edit' you can untick 'Allow Comments'
    You can do this for each individual page
  3. jlewtoo
    jlewtoo New Member
    Irvine, CA
    Thanks for your response but that box was already checked and the comment box is still not working. I believe that something will need to be corrected within the editor file. I have tried several fixes found on the forum but none of them have worked successfully.
  4. Piyush
    For this issue, paste the following code in your custom css
    (Appearance -> Theme Options -> Styling Options -> Custom CSS).
    p.form-allowed-tags {
    It will remove that text.
  5. jlewtoo
    jlewtoo New Member
    Irvine, CA
    Thank you. That took care of the first issue, however I still need help with the second issue. Even though I was choosing the allow comments box no comment box is appearing. Please advise, thanks!
  6. Nitesh
    To add comment form in fullwidth pages, Add code given below
    in "template-fullwidth.php" (Appearance > Editor > template-fullwidth.php) as shown in image.
    <!--Start Comment Section-->
                  <?php comments_template(); ?>
                  <!--End comment Section-->
    To add comment form in default pages, Add code given below
    in "page.php" (Appearance > Editor > page.php) file as shown in image.
  7. jlewtoo
    jlewtoo New Member
    Irvine, CA
    It worked! Thank you!
