Theme Font breaks down with W3 total cache
Discussion in 'Infoway WordPress Theme' started by tekkentim, Mar 28, 2013.
  1. tekkentim
    tekkentim Guest
    Hi Everyone,
    I've used the Bizway theme for quite some time now, and wanted to try a different theme, so i started using Infoway.
    I always used W3 total cache with my wordpress sites, but somehow Infoway does not work with any cache or minify plugin.. When i enable the pluging, the font crashes, and shows weird stuff.. I switched back to Bizway, and the problem was gone..
    I think it has to do something with the font.. or the .css..
    Could someone please explain what to do in order to use W3 total cache, or any cache tool for that matter with the Infoway theme ?
    Thx.
    tim
  3. tekkentim
    tekkentim Guest
    Hi Piyush,
    It happens to every site.. whenever i switch to Infoway, and enable W3 total cache / minify settings, the site gets screwed up.. at the moment i switched back to Bizway on my site, and the problems are gone instantly.
    One site: www.nespressocupsbestellen.net - i changed back to Bizway, but i really want to run Infoway with W3 total cache enabled..
    Should i switch back to Infoway for a few hours, so you can see the problem ?
  4. Gourav
    Issue resolved, Download updated version of theme from your members area and upload it, This will solve your issue, If not then,
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    And also send the screenshot of your problem, About which area you are talking.
  5. tekkentim
    tekkentim Guest
    Hi Gourav,
    Please check http://www.nespressocupsbestellen.net in different browsers, its only the first page that is breaking down font-wise..
    As you can see the weird font characters appear.. Â etc..
    Will mail you my info straight away..
  6. tekkentim
    tekkentim Guest
    Hi Guys,
    Any news regarding this issue ? thx in advance.
  7. Piyush
  8. tekkentim
    tekkentim Guest
    Hi Piyush,
    Replied to your mail, problem still exists
  9. Gourav
    We are not getting your issue. Please explain with the help of the screenshot, About which area you are talking and also specify in which browser you have gotten this issue.
  10. tekkentim
    tekkentim Guest
    Hi Gourav,
    Please see 2 screenshots.. One with Cache program enabled ( messes up the font on the front page ) and one with cache program disabled.. everything returns to normal..
    At the moment i enabled W3 total cache, so now you can see the problem on the site ..
  11. tekkentim
    tekkentim Guest
    I just checked the site again, and it seems that you disabled W3 total cache, which resolves the issue.. But that is not the problem.. the problem is that this theme breaks down with W3 total cache enabled.. Could you please let me know how to get this theme working with a cache program ?
  12. Gourav
    Issue resolved.
    Check image for reference
    Note:- Clear your system cache.
  13. tekkentim
    tekkentim Guest
    I understand that disabling W3 total cache resolves this issue.. But i want to enable w3 total cache without the font breaking down..
    Problem still exists.. ( check firefox )..
    Without W3 total cache, wordpress is really slow..
  14. Piyush
    We are working on this issue and reply you as soon as possible.
