Hello, I have tried to generate a login-page with the [login_reg] Shortcode. Unfortunately its not working. The Page is loades (blank) and then redirected to the homepage of the site. It seems that something is missing, If that information is helpful for you: I use the inkmember-pro Plugin on a Wordpress Site without the Subscribely-Theme Thanks for your reply Jens
Hello Jens, Greetings from InkThemes! It seems that you are trying to access your page while you are already logged in.. So you are kindly requested to log out first and then access your login page.. Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
