How can I fix the problem below Driving Lessons in Milton Keynes drivinglessonsinmiltonkeynes.info/ A description for this result is not available because of this site's robots.txt – learn more. You visited this page on 13/10/13. thanks Mike
Hello, You can try "WP Robots Txt" plugin , it will helps you. Download it from the link given below and upload it from the plugin panel, in your dashboard. http://wordpress.org/plugins/wp-robots-txt/ I hope this will solve your issue.
Thanks tried that, changed text content to User-agent: * Disallow: and still not working. Any more help please www.drivinglessonsinmiltonkeynes.info Im new to this stuff, please keep it simple many thank Mike
Hello, Please follow the link given below http://www.corephp.com/blog/ultimate-guide-write-perfectly-optimized-robots-txt-file-wordpress/#. I hope it will help's you. And we have visited your website, it seems that you have forgotten to put Google Analytic code within the script tags in your dashboard. So, please put the Google Analytic code within the script tag as given below. For example: Code: <script type="text/javascript"> Put your Google Analytic code here </script>
Did say new to this, how and were do I put Google Analytic code within the script tags in your dashboard.
Hello, Go to the Appearance > Theme Options > General Settings panel in your dashboard and put the Google Analytic code within the script tag in the Tracking Code section.
Tracking ID UA-44872705-1 Status: Receiving Data Website tracking This tracking code can be used on drivinglessonsinmiltonkeynes.info or any drivinglessonsinmiltonkeynes.info sub-domain (www.drivinglessonsinmiltonkeynes.info, blog.drivinglessonsinmiltonkeynes.info, etc.). To track visitors across other domains you own (drivinglessonsinmiltonkeynes.uk and drivinglessonsinmiltonkeynes.cn, etc.), please refer to the cross-domain tracking guide. This is your tracking code. Copy and paste it into the code of every page you want to track. Put this into most pages I want to track <script> (function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]||function(){ (i[r].q=i[r].q||[]).push(arguments)},i[r].l=1*new Date();a=s.createElement(o), m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m) })(window,document,'script','//www.google-analytics.com/analytics.js','ga'); ga('create', 'UA-44872705-1', 'drivinglessonsinmiltonkeynes.info'); ga('send', 'pageview'); </script> And this into the place you said <script type="text/javascript"> UA-44872705-1 </script> Still not working
Hello, We have checked your website source code and found that Google Analytic code is working fine. See the image for reference. Check the link for reference https://support.google.com/analytics/answer/1032399?hl=en Google takes some time to fetch content of the website.
