Pro Version No Options
Discussion in 'General InkThemes Discussion and Feedback' started by keithstern1, Apr 12, 2018.
  1. keithstern1
    keithstern1 Guest
    I've just downloaded the Pro version of Butterbelly after paying, and it's got much less customise options than the Lite version? Disappointed!
    How do I get all the extra customise options in the advert to get me to upgrade?
    Photo evidence ...
  2. akbar92
    I would like to tell you that - The pro version of the theme has a separate customizing panel which is named as (InkThemes) where you can find all the customizable options of the theme. Just go to (Dashboard->Inkthemes). Please have a look at the attached screenshot.
    Hope this helps...!
    Do let me know if you need further assistance.
    I will be glad to assist you.
    Akbar
  3. keithstern1
    keithstern1 Guest
    Thank you Akbar ... I now understand where the customizing panel is.
    Would it not be a good idea to add this extra customisation to the normal 'Customize' section, so one can see the customization in real time as you make the changes?
    Keith
  4. akbar92
    Hello Keith,
    I have got your concern and would like to tell you that - We are porting the InkThemes options to the default theme customizer.
    You will get this feature in the next update.
    Akbar
