My home screen has little dots separating each section! Help!?
Discussion in 'Squirrel WordPress Theme' started by niagarahub, Aug 29, 2013.
  1. niagarahub
    niagarahub New Member
    Hi... I'm new to all this and forums, etc - but it seems like this might be my only chance at help! My main home screen has little dots (like a marquee somewhat) separating each section area... doesn't look good and it just started doing that... anyone know why or can lend some advice?
    Can you please explain your problem with the help of screenshot, what you want to do and also share the link of your website, so that we can give you the exact solution.
  3. niagarahub
    Yeah, I should'a done that... my fault... the website address is www.nfeducationfoundation.org and you'll see that there are like dotted lines where there shouldn't be (above the "Together we are one" and the bottom half of screen. They weren't always there, just sorta appeared! Attached is a screenshot too... thank you for any advice!
  4. Gourav
    Paste this code in Custom CSS
    .slider-info {
    border-top: none;
    .text-featute {
    background: none;
