Hello, I am trying to make a custom color of the navigation buttons different from the choices you have. You have psd files in the members area but they are helpful to change button color. The uploaded file is one of the button color images. Do you have a psd for this? I tried to fill them with a new color but it looked really bad. Thanks. Also, how do you change the text link color. It is a light blue-ish. When I look at it, it says it is a cufon text. Thanks! Matt
Hello Matt, Please share color code which you want in place of black color for button. I will provide you button with your desired color. For cufon: Go to the Theme directory > js > custom.js and remove cufon code from there as shown in the image given below. After that you can change your font color. Thanks & Regards Nitesh Raghuwanshi
Hello, Please download "nav-black" image attached and replace it with your current "nav-black" image.
