Changing link color
Discussion in 'Squirrel WordPress Theme' started by adamsmark, Mar 12, 2013.
  1. adamsmark
    adamsmark New Member
    I'm going through the CSS file, looking to change the link color for links in pages and posts only. How might I do this? Should I add something to the custom CSS or modify the CSS file directly? What code should I use?
    Please explain your problem with the help of screenshot, where you want to change the color and also share the link of your website, so that we can give you the exact solution.
  3. adamsmark
    I'm talking about links within pages and posts. See http://2-xl.net/?page_id=17. All I want to do is change the color of links within text, but only inside the test of posts and pages. Right now, they blend in too much with the text.
  4. Gourav
    Paste this code in Custom CSS
    .page-content .content-bar a {
    color: blue;
  5. adamsmark
    I know a little about HTML and CSS. I can put "red" or "blue" in that snip of code, but not color hexes, e.g. 000099. Why is this? Also, what if one wanted to change the "hover" color? Where in the existing code are these styles?
  6. Piyush
    You can also put color code inplace "blue". for example
    color: #C95757;
    Please specify your issue little more that on which text you want to change the "hover" color.
  7. adamsmark
    The same link. If I use this code to change a link's color
    color: #C95757;
    What code do I use to change its behavior when I hover over it?
  8. Gourav
    .page-content .content-bar a: hover {
    color: #C95757;
  9. hghplus
    hghplus Member
    How do I go about changing the color of the links that I add to the widget area. They default to grey.
    Also some of the body's text is grey and some is black. I try to change and it does not.
    Thank you.
  10. hghplus
    hghplus Member
    Thank you.
  11. Gourav
    Do let us know your website link.
  12. hghplus
    hghplus Member
    The URL is docwellnessformula.com
    Also if I may ask, how do I change the footer color from dark grey to blue. Thank you kindly.
  13. Piyush
    1. For your first issue, paste the following code in your custom css
    .wrap_sidebar p.more a {
    color: red;
    2. For your second issue, paste the following code in your custom css
    .content p {
    color: green;
    .content em {
    color: green;
    .content strong {
    color: green;
    .content ul li {
    color: green;
    .content_wrapper .content p span {
    color: green ! important;
    .content_wrapper .content span {
    In place of green and red you can put you color or color code.
  14. Piyush
    Go to the Styling Options Panel(Appearance -> Theme Options -> Styling Options) in your dashboard and choose your color from the Theme Color Options section.
  15. hghplus
    hghplus Member
    Thank you kindly. I appreciate.
    One more question. How do I go about changing the link color of the BODY links?
  16. Krish
    Krish Support Staff
    India
    Just put bellow example code in styling options
    a{
    color:your color;
  17. hghplus
    hghplus Member
    Did not work
  18. Piyush
    Please specify your issue with the help of screenshot images that where you want to change the color.
  19. hghplus
    hghplus Member
    When I add a link to my page(s) (in the body section), it defaults to grey and despite my changing it, stays the same color.
    The URL is http://docwellnessformula.com/
    Thank you.
  20. Gourav
    .content_wrapper .content a span {
    color: red!important;
    Inplace of "red" put your color code.
