Blackwell theme
Discussion in 'BlackWell-WordPress Business Theme.' started by ree157, Aug 10, 2014.
  1. ree157
    ree157 New Member
    hi, i uploaded and installed blackwell theme, the theme is cut off at the right end and this looks bad, please send me a fix for this. site is http://www.oceandelight.co.za/
    thanks
  2. Pramod
    Pramod Guest
    Download theme again from your members area and upload it.
    Pramod Patel
  3. ree157
    ree157 New Member
    hi. i downloaded the theme again and uploaded but nothings changed, see attached
      File size:
      267.4 KB
      5
  4. ree157
    ree157 New Member
    blackwell theme is flashing continuosly and does not set correctly on my screen, very disappointed, please check it out asap
  5. mischelle
    mischelle New Member
    I am having exact same problem, I posted on the other post as I didn't see your post :)
  6. mischelle
    In another post they said to change the slider speed, I can't find that, it flashes over and over and they said go to "Appearance ->Theme option ->Home slider settings)of your dashboard and manage speed of slider" I can not see the Manage Slider Speed anywhere.
    I see there is another post on this forum about the continuous flashing of the main slider, but the post is locked so I can't post on that one.
    Can some help, I really want to use this theme and need help very quickly....
    Thanks in advance.
  7. Pramod
    Pramod Guest
    Hello mischelle,
    Left sidebar push the content in right side and this is the feature of theme.
    you can close left side bar after clicking on particular section by clicking on a small image just right to the left sidebar and on the top of the website.
    After closing the sidebar you find that your site work perfectly.
    For slider speed go to
    and set false in the place of time.
    Pramod Patel
  8. ree157
    ree157 New Member
    Pramod Patel, did you not see my post, what do i do to sort my issue, adjusting the slider settings does not solve anything and why is the theme cut of towards the right of my screen, please send me a fix asap. my dissapointment continues
  9. mischelle
    Hi Ree157,
    I am so sorry that they didn't answer your question, I feel like I hijacked your post, my problem isn't fixed either, there is no slider speed on mine.
    Have you checked your "Theme Options/Styling Options" to make sure the Theme Language is Default and not RTL.?
    It's the only thing I can think of that as I am fairly new to this.
    Cheers
  10. Pramod
    Pramod Guest
    Hello Ree157,
    Sorry for delay.
    Pramod Patel
  11. ree157
    ree157 New Member
    No problem Mischelle, i just removed the blackwell theme, goodluck
