Hello, I need help with the following: On the main page of the theme there is a blog area, I want to change the two banners that are on the sides with my client's advertising. How do I change them? The template has a shop window and I want to put each one of the products and its description. How do I do it? and finally, in the contact table I want to place the descriptions of name, mail, subject, etc in Spanish. Thanks for your help and I look forward to your prompt response
Hello, Greetings from InkThemes, You can change those images from the widgets settings (Homepage Blog Left Sidebar & Homepage Blog Right Sidebar). Go to (Dashboard->Appearence->Widgets) and put the text widget into the Blog Left & Right Sidebar widget area and then insert the image URL in between img src tags. Please have a look at this screenshot: https://screenpresso.com/=bfvLd Just follow this linked video: https://screenpresso.com/=ETCBd I would like to recommend the below-linked plugin in this regard. 1. https://wordpress.org/plugins/loco-translate/ Hope this helps...! Regards, Akbar InkThemes.com
Hi. I do not see the option of products that the video shows. How do I get it displayed? Because if it is a plugin, none comes The rest helped me a lot. Thanks
[QUOTE = "checharun, post: 91351, member: 40849"] Hola. No veo la opción de productos que muestra el video. ¿Cómo lo hago mostrar? Porque si es un complemento, no viene El resto me ayudó mucho. Gracias [/ QUOTE] Ya te lo instale checharun... saque chispa mi rey!!! jejejjeje
Hello, To edit the product description, Go to (Dashboard->Products->All Products->Product Short Description) and start writing the description. Please have a look at the attached screenshot. Hope this helps...! Regards, Akbar InkThemes.com
Hi, I have a question. I want the page that I have of equipment, show all the products that the company has and its characteristics. In the same way as in the "shop" page of the sample. How do I do that? Thanks, for your help Julio C. Morales
Hello Julio, Thanks for getting back to us, You can create an Equipment as a product category and assign your desired products to this category and the then use this category as a page via the menu. Go to (Dashboard->Appearence->Menus), Please have a look at the attached screenshot. Hope this helps...! Regards, Akbar InkThemes.com
Hi. Could you help me. How do I remove the "add to cart" button from this page and from all the pages where the products are?
Hi, Greetings from InkThemes, To remove the add to cart button, just paste the code given below in Additional CSS section. (Dashboard->Appearence->Customizer->Additional CSS) of your dashboard. Code: .add_to_cart_button { display: none !important; } Hope this helps...! Thanks & Regards! Akbar InkThemes.com
Hello, Thanks for getting back to us, Will you please share your website URL here? So that we could give you an exact and appropriate solution to you. I look forward to hearing from you. Regards, Akbar InkThemes.com
Also, I want to know how to do, so that this banner moves automatically every 3 seconds. Thank you for your cooperation
Hi, Greetings from InkThemes, To remove the add to cart button from the homepage, please add the code given below in Additional CSS section. Code: .ajax_add_to_cart { display: none !important; } We need WordPress admin credentials to configure it. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will do it for you. I look forward to hearing from you. Thanks & Regards! Akbar InkThemes.com
Hello, Greetings from InkThemes, To remove that section, just paste the code given below in Custom CSS section. (Dashboard->Inkthemes->Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .header-info .header_cart_items { display: none !important; } Hope this helps...! Thanks & Regards! Akbar InkThemes.com
Hello, I want to ask you how do I make the main banner move automatically? Thank you My page is http://www.masmenos.com.gt/repinca/
Hello, I also want to ask you how to order the products to my liking. I mean how to change the order of each item
Hello, Thanks for getting back to us, We need WordPress admin credentials to configure it. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will do the needful. I would like to recommend the below-linked plugin in this regard. 1. https://wordpress.org/plugins/post-types-order/ Hope this helps...! Do let me know if you need further assistance. I will be glad to assist you. Regards, Akbar InkThemes.com
