Important Note
We have shifted our support forum with more advance feature, So if you are Pro buyer at InkThemes.com, Do ask all your support queries at http://www.inkthemes.com/community
InkThemes Support Forum » Cloriato Theme
3 column images links?
(8 posts)
  1. sjclf
    Member
    Member
    Is it possible to have the 3 column images act as buttons to go to a link? They have built in hover function, but no link option so it makes them very curious on the website.
    Posted 10 months ago #
    Support Staff
    Support Staff
    Download theme again from members area, This will solve your issue.
    Thanks.
  3. sjclf
    Member
    Member
    Downloading and re-installing the theme did not correct this issue
  4. Gourav
    Support Staff
    Support Staff
    Please send your wp-dashboard id and password with problem description
    at support@inkthemes.com
    Thanks.
  5. kimharp
    Member
    Member
    I've noticed the same thing. Are the 3-col homepage images themselves supposed to act as links, or just the text above them? It would be great to have the actual image be a link.
    Posted 7 months ago #
  6. Gourav
    Support Staff
    Support Staff
    @kimharp,
    Download the updated version of theme and upload it, This will solve your issue.
    Thanks.
  7. kimharp
    Member
    Member
    Ok, sorry if this is a stupid question but I have v. 2 of Cloriato Pro. Is that the latest version? I can't find anywhere on this site what the current version is and I'm not seeing anything about updates on my dashboard.
  8. tomw497
    Member
    Member
    I am having the same problem and I know you have said to re download the theme. If I do this will I loose everything I have done to the theme already it already?
RSS feed for this topic
Reply
You must log in to post.
